Results 1 to 10 of 14
Thread: Cheap D3/D4 Snorkels - how do they rate?
    May 2002
    Sydney, Australia
    Hi All,
    I've seen all these listings on eBay for cheap D3/D4 Snorkels (Raised air intakes) - does anyone have any direct experience with these?
    Most seem to be about $150-$200 whereas the original Safari ones are $500+
    Cheers LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Bangor, NSW
    I have no first-hand experience with the cheapies, but the following website influenced my purchase: Don't Get Burnt - Low Quality Snorkel Copies
    Sep 2011
    Minyama
    Is that an independent article or an advertisement?
    sheerluck Guest
    Quote Originally Posted by rufusking View Post
    Not quite independent. The testing was requested by Safari, and that website is owned and hosted by the same name as the Safari website.
    The testing looks like it was conducted by an independent lab, though the test was conducted to an Australian Standard that was modified "to client's request". Read into that what you will.
    Personally I think it's an Aussie company making an attempt to protect their IP, and trying to show their products in the best light possible, but it is just a little hamfisted.
    And whilst I have no issue paying for a quality product, a slightly different plastic blend, and a slightly modified moulding process don't make a product worth two and a half times as much.
    Sydney, Australia
    Not independent at all:
    "It is our strong belief at Safari that inferior materials and manufacturing techniques have no place on vital components such as snorkels. As 4WD enthusiasts, we rely on our snorkels for total peace of mind against water and dust. That can only be achieved with a snorkel you can trust – the genuine Australian made Safari snorkel system."
    I find it a bit misleading that they use a different web address not mentioning Safari.
    However Safari snorkels are much better and the Chinese ones vary a lot. Some have been really bad some better.
    It the very least they will need more fiddling and adjustment to fit.
    You get what you pay for really.
    Dec 2008
    Prospect 2148
    I have one that I got from a forum member, but I am pretty sure he got it from Ebay or another company that sells these cheap snorkels. I had it fitted professionally. I was warned that there might be problems with the fitting and there were. so it cost mor to fit. It still ended up at about the cost of a Safari (without including fitting). It is working well.
    One problem was the hose - it was not long enough or frankly of sufficient quality, so one had to be purchased. The other issue with the fitting were all to do with nor matching the supplied template.
    If you are intending on fitting yourself, then measure, remeaure and remeasure.
    Mike
    Jan 2012
    Australia
    Just get a safari and fit yourself, easy as and worth the money.
    Mar 2011
    Balbarrup WA
    cheap snorkels
    Have a cheap Ebay snorkel on my D3 for past 3 years, used mostly to avoid dust, as not much water in Pilbara. So far only complaint would be that they could have used stainless bolts to fix it to bracket. Hasn't broken off or disintegrated in the Pilbara sun.
    It was no problem to mount, all fitted quite well.
    Have bought "Australian made" snorkels for other vehicles only to find them arrive with holes in the plastic moulding, suggesting quality (at times) might not be a lot better than cheapie Ebay specials.
    Aug 2011
    Perth West Aus
    Gotta agree with vbrab I've had my 160 dollar cheapy on for a couple of years fitted in myself with no problems other then needing to sharpen drill bits a few times. Hasn't faded cracked or self destructed in any way.
    Sydney, Australia
    Quote Originally Posted by jonesy63 View Post
    Always read everything in context especially who wrote it.
