Thread: Wing Tops
    Jan 2009
    Kuranda, Far North Queensland
    Wing Tops
    I am trying to find an Australian supplier of checker plate wing tops for my series 2a. Anyone been able to source them here?
    Thanks,
    Howard
    Jul 2011
    Logan
    MR Automotive gets them made local. Had some there the other week when I was down there.
    Jan 2009
    Got two and fitted them. Now to do the paint job!
    Thanks for the lead.
    Howard
    Quote Originally Posted by landiematt View Post
    Got some aluminium chequerplate, cut them out with a saw, trimmed the edges and made the curved corners with a power planer, drilled and installed them. One morning's work several years ago. (You can work alloy with woodworking power tools!)
    Aug 2012
    Adelaide
    I'm sure you can.... but how long does your nice sharp blades/tools stay sharp for?
    Quote Originally Posted by debruiser View Post
    If they are carbide tipped they will be unaffected. Steel cutting implements are unlikely to be affected either.
    The only catch, and it is a real one, is that the cutting angle on the woodworking tools is not ideal for alloy. For this reason you should use a shallower cut on a planer than you would on wood, and take it slower with a power saw.
    I learnt this from a boatbuilder after watching him smooth off the welds on the outside of an alloy yacht hull with a planer.
    Aug 2012
    Adelaide
    I think I will try this next time I'm working with ally. Thanks for the tip.
    Sent from my A 8 using AULRO mobile app
