Results 1 to 10 of 23
Thread: Door Repair
    Nov 2013
    Jarrahdale W.A.
    Door Repair
    Ok, I'll admit it! I Don' know if its just me but I am rubbish at searches on this forum! I am sure the answer is on here, but I cannot find it!
    Anyway, my next big job on my 110 (Hector) is to repair the doors. Each time I close them there is the gentle tinkling sound of rust falling down - they all are in pretty bad shape with most of the bottom rusted out, and blisters in the paint at waist level. I and going to need to get the steel work out and cut out the rust and weld in new. The rear drivers side door also has no door card, winder mechanism or really anything - so I need a lot for that!
    So, here's the question. Where is the best place to get the "door bottom repair section"?
    Also, any one out there that has done this and want to share their valuable knowledge/ i would love to hear from you.
    Thanks in advance!
    Geelong, VIC
    Watching with interest as I've got to do the same thing.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Camp Hill Queensland
    I have previously bought repair strips of SIII door frame from FWD motors in Melbourne to do this job, but have never completed it. Not sure it it is 100% the same profile of more recent door frames.
    '95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
    '85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
    '76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
    Nov 2013
    Jarrahdale W.A.
    Quote Originally Posted by isuzu110 View Post
    I have been given the name of this company, but can't locate it. Any more info out there?
    Nov 2013
    Jarrahdale W.A.
    Went on this web site, but they only seem to have filter kits, service kits and insect repellant!
    Narre Warren South
    Quote Originally Posted by KeithMac View Post
    Phone them and speak to Jim or email sales@landrovers.com.au
    They have repair sections for Series doors, not sure how different the 110 profile is and whether they keep it in stock.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Nov 2013
    Jarrahdale W.A.
    Quote Originally Posted by gromit View Post
    Colin
    Thanks Colin, I'll send him an email.
    Keith
    Geelong, VIC
    How did you go Keith?
    Were you able to get hold of the repair sections from somewhere?
    Steve
    Dec 2010
    Batemans Bay mostly, and Brisbane
    DOOR BOTTOMS
    I have had to do this about a dozen times- front defender type and rears, county 110 and series. Haven't noticed much difference between them all- just some detail changes but not so much in dimension of the box section. It's fiddly and annoying work- esp around the door hinge tube sections (hidden within the box at each hinge) these are simple crush tubes 12mm or in diameter I recall- they are brazed in. They get rusty and must be replaced as the hinges can't be tension on the door without them. An additional area that can't be ignored is the rear upper section on the rear doors just south of the quarter window. Defenders love to rust here.
    I have seen the repair sections available on eBay and other places but refuse to come at the cost of something I can make myself. Given that steel is fairly cheap, I have made up a jig to bend the light gauge .75mm steel after cutting to length and width. I use a male and female setup so just crush the steel to shape and then spot weld to flat sections- similar to factory except they used a press. Zinc aneal is preferable and make damn sure you put some sort of product like tectyl on the inside of the welds after getting some etch prime in their prior. Tectyl comes in spray cans and you can put one of those red tube thingies into the nozzle to put it in hard to get spaces. I have tried pouring the stuff in to the box section using a hand pump, turning the door on it's end and over again but this is very wasteful of product and it goes everywhere- a wretched experience believe me.
    The hard part is folding the ally skin back and keeping it from the heat of any of the welds. Be prepared to refinish the door entire. Use adhesive sealant (sikaflex) to stick the skin to the back of the repaired sections. Two person job to stretch or tension the skin back into place.
    HTH cheers
