Yes
 Fossicker
						Fossicker
						Ive got a 2013 110 and I have been looking on Gumtree for an ARB bull bar (2nd hand). There are a few that come up and they are from 110's earlier models eg. 2001, 02 etc.
Does the new model (eg mine) have the same mounting points for the bull bar and therefore allow me to purchase one from an older model Defender?
Yes
Just make sure that you get a longer mount version that clears the grill
 Fossicker
						Fossicker
						When you say a 'longer mount version', is that a separate piece to the actual bull bar?
No.. All one piece, just make sure it came off a Def with the forward mounted grill
'88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
'85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
'56 SI Ute Cab
 Wizard
						Wizard
						When I brought my first ARB bar , It was for a County that had the extended aircon grill . It wouldn't fit as It couldn't go back far enough , not by much ,but as I say enough to stop It . So a bit of measuring , a bit of marking , out with the small angle grinder , two small bits cut at the back , and on It went no problems at all , put some black paint on the cut area , It is still going strong to this day . cheers Jim..
 Fossicker
						Fossicker
						From what year roughly did the forward grill come into play? Also for a 1/2 decent bull bar with not too many scratches, what is a reasonable price? I was looking around the $350 $400 mark.
Early county and post 2003 should cover it.
A good 2nd hand unit goes around $500-$800
Triumph rover spares has one:
ARB http://www.triumphroverspares.com.au...&productid=386
