14th April 2014, 10:54 PM
software settings? coils
Just wondering what the correct info would be to the sequential gas programming with the software COILS.
The Zavoli software gives a couple of choices either single coil per cyl and 2 coils
The motronic system uses 2 coil packs and has a connectors for 4 cyl per coil.
So in theory it is 1 coil per cylinder, (or 4 cylinders per coil)
If I select this setting 1 coil per cylinder then the RPMs on the software are doubled, eg,. 670RPM becomes say 1340rpms on the software screen.
choosing 2 coils gives correct vehicle RPMS.
I'm still trying to remove some flat spots in the auto configeration set up.
I figure if I don't have the right info edited in the settings then I have lesser chance of it auto configuring correctly
Any clues???
Thanks Mario
15th April 2014, 06:51 AM
"two coils" actually should read "2 cyl per coil" and is the correct setting. Use the fuel map to correct any areas that need enrichment.
