Results 1 to 10 of 19
Thread: Custom Puma fuel cooler guard
    Having just recently got a new Tdci 90 to go with my TD5 90 I spent a bit of time looking over it. One of the things I didn't like was how vulnerable to fuel cooler and the hoses from it to the engine appeared.
    Original plan was to do something to protect this:
    This is the resultant item I have had made from my design, out of 4mm grade 5005 aluminium. It only weighs 4kgs
    Pretty simple to fit.
    1. Remove anti-roll bar bolts, and drop it down, then insert M8 rivnuts into already present holes in gearbox cross-member:
    2. Offer up guard, and fit bolts loosely, before tightening into place using 4 M8 bolts into gearbox cross-member and the ARB mounting bolts:
    Little tab to hold the fuel lines, which i will attach shortly with an P clip
    [/QUOTE]
    Pretty happy with how it turned out! This was the first prototype and it fits perfectly.
    PM sent
    Bit of overkill there Pete,especially as it is only going to be driven to church on Sundays
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Landy86 Guest
    Would you be interested in making these to be sold
    I'd buy one
    Jun 2008
    Drouin East, Vic
    The tray looks great and would provide a lot of protection; I'm reminded though of the pressed sheet-metal tray that used to be standard fitment under a lot of Asian 4wds in the 80s, they got a reputation for trapping combustible material like spinifex or twigs against the exhaust and causing vehicle fires, was standard practice to remove them. Do you think this might be an issue?
    Quote Originally Posted by Landy86 View Post
    I'd buy one
    Maybe yes. I will be doing a fairly long run in the car over Easter so I will check there are no unforeseen issues and go from there. I should find it easy to get these made, as there is no work beyond getting them cut and folded (welding etc) which is where I struggle due to a lack of time.
    Quote Originally Posted by POD View Post
    I don't think there will be any issues. There is a heap of room above the guard and it is open at the ends and back so if anything did end up on top it would be very easy to remove.
    Quote Originally Posted by LowRanger View Post
    I am trying not to take it out of the garage at the moment atall
    Landy86 Guest
    Would you work out a price
    Very keen
    Mar 2007
    Great Southern Land
    Thumbs up
    Mate, that looks great ! Well done on the design and build
    Pete
    1963 S2A 88 113-300 6 RAR, VTF, Vietnam.
    1989 Perentie FFR 49-290 2 Sig Regt.
    1989 Perentie FFR 49-390 1 MP BN.
    1990 Perentie GS 50-087 5 RAR.
    2013 Defender 110 Wagon, 'Snowy'.
