Thread: Globes list
    Feb 2011
    Bendigo
    Globes list
    Just wondering if anyone knows of a globe list for disco 2a's. Had a dodgy park light and indicator for a awhile. But since I don't use parkers and bullbar has indicator. I haven't bothered. But now that the headlight globe is gone. I am going to replace all..
    I have found -
    Headlight globes are all H7
    Fog lights are H11
    Jun 2007
    Margaret River
    I had a look in the manual but, it only shows wattage, not type of bulb. (see below) The specs for the bulbs may be printed on the lens somewhere
    REPLACING BULBS
    Check the operation of all exterior lights before
    you drive the vehicle.
    Replacement bulbs
    NOTE: All bulbs must be rated at 12 volts
    Halogen bulbs
    Halogen bulbs are used for dipped/high,
    supplementary high beam and front fog lights.
    Take care NOT to touch this type of bulb with
    your fingers; always use a cloth to handle them.
    If necessary, clean the bulb with isopropyl
    rubbing alcohol to remove fingerprints.
    IMPORTANT INFORMATION
    Before replacing a bulb, always switch off
    the starter switch and appropriate lighting
    switch to prevent any possibility of a short
    circuit. Only replace bulbs with the same
    type and specification.
    Bulb Watts
    Headlights dipped/high beam 60/55
    Front side lights 5
    Front side marker lights 5
    Direction indicators 21
    Front fog lights 55
    Side repeater lights 5
    Reverse lights 21
    Rear fog guard lights 21
    Tail lights 5
    Stop lights 21
    High mounted stop light 21
    Number plate lights 5
    Interior light 5
    Interior courtesy lights 10
    Glovebox light 5
    Vanity mirror light 1.2
    Sep 2009
    Narva's site helps with this. Wrong headlight bulb for D2a last time I looked though (showed h4 rather than h7). Emailed them for correction. Gives you part nr; you then need to search on nr for bulb type and wattage.
    Feb 2011
    Bendigo
    Might found the bit in the book that says the wattage. Which I thought was pretty useless.
    I will try narva.
    schuy1 Guest
    pull the old 1 out and compare!! Simple!
    Cheers Scott
    Feb 2011
    Bendigo
    Have you ever pulled a head light out. Pain in the arse job. Prefer not to do it twice.
    schuy1 Guest
    HaHaHa, yeah, I know where you are coming from just sometimes gotta bite the leaden object! Am pretty sure the main bulb is H7 60Watt, Dipped bulb is H7 55watt, side/parkers are wedge types
