As you have stated, the suspension works until you drive so off-road height should work if you don't drive after starting.  The suspension system is lowering due to a brake/steering fault - nothing wrong with the system itself.
I suspect there's a problem with the steering angle sensor, perhaps loose or a loose electrical connection or just needs to be calibrated, that is causing all the problems.  The steering angle sensor is monitored by the brake system.
If you don't have front parking sensors then the rear ones don't reactivate when the trailer plug is removed until the engine is restarted - a poor bit of design or programming.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
