Results 1 to 10 of 21
Thread: Fitting viscous fan to 4BD1T
    I want to fit a viscous hub with fan and remove the existing thermo fan setup on my 110. I have all the part numbers to buy the items but is there enough clearance between the front of the engine and the radiator? Also does anyone know if the fan will fit inside the LR radiator shroud?
    Oct 2006
    gold coast,tweed heads
    No problems on mine. The viscous fan is slightly larger in diameter.
    Thanks Eric
    Hay Point
    You might need to trim a little off the blades otherwise it will hit the bottom of the shroud. As Eric said, the fan diameter is larger. No problems with length as it doesn't have the spacer like the standard one has.
    Cheers......Brian
    1985 110 V8 County
    Jul 2013
    Quote Originally Posted by THE 109 View Post
    Did you find the viscous made the 4bd1 any quieter? It would be something I'd consider if it helped a little in the noise department.
    Oct 2006
    No in short, my truck doesn't have any carpets or sound proofing so it's too loud to notice any change. It came like that being a truck motor.
    Eric
    Mar 2015
    denmark
    hi, do you have part number and price tp dp this? cheers
    Jun 2012
    Beechworth
    Quote Originally Posted by inside View Post
    Hi, any reason why you are removing the thermo fans? I was thinking of fitting some to mine, was going to measure up and see what common twin fan set up would fit from falcon /commodore etc, thought it might take a bit of load off the motor, maybe a tad quieter, and can set up to switch off for water crossings.
    Cheers, Andrew.
    Jun 2014
    Waitakere, New Zealand
    Quote Originally Posted by nic_denmark View Post
    Even though this thread is old, I would also like part numbers.
    Sent from my Nexus 4 using AULRO mobile app
    Jock The Rock Guest
    Viscous Hub
    Isuzu Part No: NG-14055.010 Approx. $330.00 Australian
    Fan
    Isuzu Part No: NL NG-14050.019 Approx. $260.00 Australian
    Adaptor Plate
    Isuzu Part No: 897 1086430 from memory it was only about $40.00
    I got my fan and viscous hub from a wrecker, it worked out considerably cheaper
    You'll also need 4 x M8 x 20mm bolts these hold the hub to the adaptor
