Results 1 to 10 of 20
Thread: sump depth
    May 2006
    Woolgoolga
    sump depth
    Can anyone who has their sump off measure the depth from the gasket surface to the flat part of the sump closest to the crank?
    Mine measures around 32mm, and seems to hit the crank! The truck sump must be a 4be1 type I'm guessing.
    I can either mod this one or try and find the correct one, second option is much better me thinks
    May 2006
    Woolgoolga
    Here is a pic. On the winged sump there are indentations where the crank passes the sump, the truck sump I have does not have this
    Feb 2012
    Parkdale, Melbourne
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Feb 2012
    Parkdale, Melbourne
    If it helps, here are some pics of my wingless sump before I fitted it. Engine runs.
    - Justin
    May 2006
    Woolgoolga
    Thanks Justin, I thought there was a thread on it somewhere.
    May 2006
    Woolgoolga
    I see you sump drops down a second time on the flat part, that looks like the depth I need.
    Where did you get yours from?
    Feb 2012
    Parkdale, Melbourne
    - Justin
    May 2006
    Woolgoolga
    Cheers I will give them a call. Do you remember how much they stung you for it and was it new or s/hand?
    Feb 2012
    Parkdale, Melbourne
    I just asked for a second hand one and it was $165.
    - Justin
    May 2006
    Woolgoolga
    Correct sump on its way.
