 Originally Posted by
Rich84
				Sorry I should've clarified that - if ECON mode button is lit, the climate control is in economy mode and the AC compressor does not operate (clutch disengaged) so only the front pulley bearing spins.
 AFAIK the 2.7 TDV6 is fitted with a clutchless a/c compressor, relying on a pulley that breaks and spins freely if the compressor siezes so that the belt doesn't break.  It has internal valving to accomplish the equivalent of off.  However the 3.0 TDV6 is fitted with a clutch.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
