Results 1 to 10 of 16
Thread: Getting Paint off Nomenclature Plates
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    I would like to be able to remove a couple of layers of paint that a previous owner covered the set of nomenclature plates with.
    Can anyone recommend a product and method of removing the paint that will not damage the finish of the data plates?
    Here is a photograph of the current situation. It is a bit ironic that they say that a picture paints a thousand words and I want to take the paint off so I can see the words
    Kind Regards
    Lionel
    Narre Warren South
    Lionel,
    Paint stripper shouldn't damage the anodising on the plates. Scrape it off with something soft like a body filler spreader. If applied thick enough the paint should bubble up and almost be able to be removed with a wet rag, you may have to remove layer by layer.
    Try not to get any under the edges of the plate because you won't remove it without removing the plates first.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jan 2009
    Kuranda, Far North Queensland
    I just cleaned paint off mine using thinners.
    Howard
    if its the normal spray pack paint that we use for touch ups it'll come off the plates with a gurney
    hot soapy water and a sponge works too.
    Quote Originally Posted by gromit View Post
    Wouldn't the caustic paint stripper damage the aluminium?
    If they can be removed, soak them in lacquer thinners. If you have none, maybe old brake fluid?
    Oct 2003
    Godwin Beach Qld
    I would suggest you wipe it with Brake Fluid, very carefully,or better still drill out the rivets and do it on a flat surface then re-rivet it and touch up the rivets.
    Oct 2007
    Wantabadgery, N.S.W.
    Try boiling water either slowly poured over, or if you take them off, poured onto them in a dish. The heat will soften the paint allowing it to be pushed off easily if it doesn't come off by itself.
    Sep 2006
    Toowoomba Qld
    I used lacquer thinners and a plastic scraper. Let the plates soap for a while the paint should fry up and come off easily. You are best to remove the data plates from the vehicle.
    Mar 2010
    Queensland
    12.97 MB
    Hello p38a Rover,
    I think Dave means something more akin to the Gerni High pressure water cleaner
    Kind Regards
    Lionel
