Thread: Rear camping switch panel.
    Jan 2012
    Bendigo
    Just installed a switch panel for the camping stuff.
    There's a 4awg positive and negative feed from the aux battery into a 10 way fuse box, then to a 9 switch pannel.
    There's five 5amp switches and 4 30 amp switches.
    Cargo barrier is tomorrow.
    Good stuff. I'm going to have to rework mine because, with the drawers in, I can no longer remove the panel to get to the fuse block.
    Mine is shown here: http://www.rangerovers.net/rrupgrade...wer.html#ron12
    Feb 2010
    Townsville, QLD
    Looks good mate! Personally I'd be throwing a heap of solder at those joins, rough roads will have you chasing wiring faults forever!
    Jan 2012
    Bendigo
    Next time I go to the wreckers I'll grab a saab plug to replace the yellow crimp spades - I'm not overly happy with them, but there was no 30a rated solderable plug in Bendigo. Like wise with solderable 5.8 spades - so when I find some.
    Except for the earth for the switch leds it's all soldered though.
    Admittantly I've only had corrosion problems with crimped terminals - so they all get a spray of circuit board lacquer now- but I know on desert corrugations they wouldn't stand up.
    That's a really neat setup Ron. What aux stuff were you running?
    Quote Originally Posted by benji View Post
    Exterior work light
    Fridge
    One cigarette socket (the other is not switched)
    The ELV polarised socket like that below (not in that pic)
