Results 1 to 8 of 8
Thread: Side mirror dip on reverse
    Nov 2005
    Maudsland, QLD
    Ok so my both my P38 Range Rovers (HSE & SE) had dipping side mirrors when reverse was selected. I find it strange that the L322 does not do this. Is it a fault with my vehicle or is it something that has to be programmed?
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    May 2006
    Ulverstone,TAS
    It depends on how far away other cars/objects are to your vehicle as you reverse.If I'm near the corner of my carport,the left mirror goes right down until I clear it,then goes back up
    Sent from my GT-I9305T using AULRO mobile app
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Mar 2009
    maryborough qld
    Mine goes down in reverse and back up in drive.
    Queensland
    Hi Steinzy and have you got the mirror select switch set to the passenger side mirror?
    My 02 L322 did dip and when I first got the RR I reckon this feature was a ****** feature.
    Soon learnt how good it really was.
    Aug 2010
    Sunbury, VIC
    Mirror switch has to be set to the DRIVERS side for the passenger mirror to dip - don't ask me why they programmed them like that...
    Adelaide - Torrens Park
    As Gav said, set the mirror adjust selector switch to the drivers side to get mirror dip. Personally I hate it, so I leave it set to the passenger side.
    Nov 2005
    Maudsland, QLD
    Thanks guys...problem solved!
    Mar 2009
    maryborough qld
    Quote Originally Posted by BigJon View Post
    Just remembered mine stopped working once,BUGGER.Switch wasn't to pass. side!
