Results 1 to 10 of 11
Thread: Speed in 4th td5 discovery
    Feb 2014
    South Australia
    What is a safe speed to sit on in 4th gear with a td5 disco 5 speed
    I tow my race car regularly and I have heard it is not a good idea to use 5th gear for towing. 100 kmh in 4th is around 3000rpm is that safe?
    MarknDeb Guest
    read the cars manual to see what it says RE towing speed and gears, if it says nothing you are able to do the speed limit in 5th
    Feb 2014
    South Australia
    Thanx. I didn't think of that.
    I'd be towing on the flat in 5th...
    And then dropping back on inclines
    Apr 2012
    Orange, NSW
    ^ X2.
    Don't keep it in 5th under ANY strain.
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Dec 2011
    sydney - pining for the western desert
    drive by your egt's. Others may correct me but my understanding is they will be lower with more revs in a lower gear (within reason) for any given speed - especially under load
    Adelaide - Torrens Park
    Quote Originally Posted by Alex 110 View Post
    I think the concern is gearbox strength rather than engine EGT.
    depends on the weight your pulling and the general conditions. (wind, roof rack, surface conditions)
    I'll back tombies advice on this one.
    Jul 2009
    Lake Macquarie NSW
    EGT's have a great way of telling you how hard your engine is working and henceforth how much strain is on your box. I tow a 2300kg van and while I use 5th, it has to be under the right conditions, ie, flat road, minimal headwind cool ambient ect. I try to not pull any more than 15psi boost whilst in 5th and under these conditions I can maintain the magic 90-95.
    Ideally, 4th is the go but the revs do get a bit tedious at times. Mechanical sympathy is the rule of this subject.
    Robbo
    Nov 2007
    On the road.
    4th and 3000rpm gets annoying so I use 5th on the flats bits and downhill keeping egt's under 500'C.
