Results 1 to 10 of 14
Thread: 6 Speed life.
    Townsville
    6 Speed life.
    Hey all,
    What is the accepted life of the 6 speed in the disco 3?
    Dad is getting his rebuilt at the moment.
    Better now than half way up the Tele Track they are due on in 5 weeks.
    Will.
    Jul 2009
    Are you saying he is getting it rebuilt as a precaution rather than because its stuffed?
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Townsville
    There was dirty oil and a lot of metal filings in there when he took it in to get serviced.
    It had a bit of a clunk when taking up drive out of a corner.
    Will.
    JamesH Guest
    Gosh.
    How many kays and what year model is it? I don't like to think of a gearbox rebuild being necessary on any D4 at this stage. Service and flush, fair enough but a rebuild?
    What are they made of? Souffle?
    Ellendale Tasmania.
    It should last the life of the car I should think, as long as it is serviced (flush) every 60,000 to 80,000ks.
    Baz.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Townsville
    Quote Originally Posted by Redback View Post
    Baz.
    I would love for anything to last the life of a vehicle, but that just does not happen. Everything wears. They are having their lower control arms replaced too.
    By the way it is a 2005, has 195k on it and has done the last 60 odd towing a Kimberly/ track trailer with a lot of gear.
    Will.
    Sep 2011
    Whitsundays and sometimes Sydney
    i thought the ZF gearboxes were pretty good and should last quite a few
    hundred thou K's, i know personally that the sealed for life message got replaced with the flush about every 80 to 100K KM's, had it done on my old sport
    Jim
    Townsville
    Quote Originally Posted by zilch View Post
    Jim
    When was the sealed for life thing replaced with sensibility?
    The guys at Emanuel tranny's seem to think that they don't have the best life span.
    Be grateful though. Ford would charge twice the amount for the same parts they said.
    Will
    Sep 2011
    Bizarre as the ZF gearbox is actually the most common tool in most manufacturers gearbox as they say, so why would you deem it a LR problem ???
    I purchased my first Sport in 2006 and was informed by the UK forums such as D3 and rrsport that most dealers in the UK had been informed to start changing the transmission fluid around 2008/2009 and not go with the sealed for life approach, i am not sure but there may have been a LR instruction on it as well.
    I noticed when i had my done that that the gear change smoothed out once again, and less shunt characteristics when changing up. Trouble was to do a proper flush would need the body off/gearbox out and change the filter, so many have avoided this and just gone for a straight fluid change, rather than 2 x transmission fluid flush/replace...
    Sep 2010
    east gippsland
    G'box rebuilds
    Hi Will,
    195k not bad!!! Mine was rebuilt at 165k. Ex Sydney car that I had bought at 90k had the flush at 125k and still got very clunky and a bad delay when shifting from neutral to drive. Rebuild is also an upgrade of a few components that should make it last a lot longer the second time round.
    HOWEVER--Here is my advice. Before you or your dad drive out of the workshop, take the time to crawl under the vehicle and check the turbo crossover pipe mounting brackets. There are 3 of them and the one at the 12 o'clock position is all to often being left off after the gearbox rebuilds. Apparently its a PITA to reinstall and very difficult to see. If however it is not in place the turbo crossover pipe WILL eventually break. Repair bill--- between $2500 and $5000 depending on who you got to for the repair. It happened on mine after 4mths/12000k and 8 months later I'm still in discussions with the repairer over compensation.
    Hope your trip to the tip goes well but make sure that bracket is there before you leave.
