Results 1 to 10 of 18
Thread: TD5 Gurus please hep
    May 2010
    Ballarat
    The vehicle is a 1999 dual cab tray back 130, EGR removed, TRS remap and a D2a inter cooler. It was also fitted with silicon hoses just before the start of my problems(probably coincidence).
    After the motor started to miss, we noticed a high pitched scream coming from the fuel pump. This was accompanied by a lot of bubbling and knocking sounds from the fuel tank Thinking I had a fuel pump failure I managed to limp 200 kms home, but after fitting a new fuel pump I still have a very sick Defender.
    Problems are.
    Hard to start and when it does, only on a couple of cylinders and wont rev. Other cylinders slowly come in as it warms up but still misses if you try to rev it and blows out clouds of smoke, the more throttle you give it the more smoke comes out the back. If you can get it up to 2000RPM it starts to run smoother
    So far I have fitted a new Fuel pump and filter, cleaned the plugs on the computer, removed turbo hose to manifold as I had only fitted the silicon hoses that week and thought maybe there had been a bit of packing material in one. All to no avail. This problem also started about 70 kms after filling with fuel although I could not see any water in the filter when I changed it. I have a Nanacom but must admit to not understanding all the information it gives me.
    All suggestions or help to work through the problem gratefully received.
    Ps vehicle has not been overheated and is not losing water or pressurizing.
    Cambewarra, NSW
    Have you checked for oil in the injector harness at the red ECU plug and the wiring connector on the cylinder head ?
    Kingston, Tassie, OZ.
    I would suspect a lower sealing washer failure, allowing combustion gasses into the fuel gallery.
    JC
    May 2010
    Ballarat
    Thanks Gazk I have given it a good clean at the computer end, I had a look at cylinder head end but it appeared clean so I just pluged it back in. In hind sight I will give that end a good clean tomorow.
    Cheers Dave
    May 2010
    Ballarat
    Thanks J C could you please tell me where the lower sealing washer is situated and if there is any way I can test if this is the case.
    Cheers Dave
    Jul 2009
    Lake Macquarie NSW
    Not to steal Justin's thunder because he knows far more about the Td5 than I do, but the "washers" are the copper washers on the bottom of the unit injector that seals out the combustion pressure as this motor is direct injection.
    The only way to check is to pull all 5 and have a look. Probably not a bad idea anyway then you will know for sure. Replace the upper "O" rings also. Use only genuine parts for this.
    If a washer is crook, it will let in combustion gasses to the fuel gallery in the head making it hard to start and run like a dog. There may also be a crook injector solenoid.
    Back to you JC
    Robbo
    Thanks robbo, been busy. You have summed it up perfectly :-) . Search on here in good oil should reveal the procedure. Jc
    Jan 2014
    Mount Gambier, Blue Lake City
    Dave,
    Don't suppose you accidentally filled it with petrol by any chance?
    Or have you run a number of tanks of diesel through it since the initial pump problems?
    Had similar hard to start/rough running/blowing smoke problems when I stupidly filled my Defender Td5 with petrol some years ago.
    Cost me $800 from memory to have the tank drained & fuel system purged, but fortunately no lasting damage.
    Alan
    May 2010
    Ballarat
    Thanks Robbo And Justin. It would certainly exsplain the nasty noises coming from the fuel tank although I am suprised as I had the head gasket, plastick dowls and injecter washers replaced as preventartive maintenance 40,000 klm back.
    May 2010
    Ballarat
    Hi Rurover, I did ask myself that question as it was runing great untill
    I put that last tank of fuel in, but I have had a good sniff at the tank and cant pick up any petrol smell.
    Cheers Dave
