If it thinks it is at extended when raising a sensor is suspect or it needs a calibration I would think.
Is it possible you touched the wiring to one of the front sensors when getting to the valve block?
I have seen similar problems when one of my GOE rods wasn't changed back from off road and the others were. It couldn't level and kept trying and would overheat or fault.
