Results 1 to 10 of 24
Thread: Time to phone a friend....D4 Aux diesel tank.
    Jun 2013
    Nr Freo
    Ok Guys....after much perusing.......D4 aux diesel tank.... do i go gravity feed or Elec pump......i am in a quandary........Hmmmmmm
    May 2011
    Orange Grove WA
    Quote Originally Posted by samandfee View Post
    Ok Guys....after much perusing.......D4 aux diesel tank.... do i go gravity feed or Elec pump......i am in a quandary........Hmmmmmm Cheers
    I am happy with my gravity feed.
    A search of Exploroz and other forums do talk about transfer pump failures.
    I had a transfer pump fail on the CSR a few years back. Managed to get it fixed, but a couple of hours at the end of the day working on the tank and pump was not my idea of fun....plus took some time to get the diesel smell off my arms.
    Brett......
    I have electric pump. Have to admit I have had to replace one pump in the two years I have had it, it was a leak and not a failure of the pump.
    Having said that I like the control it gives you and you know exactly how much you have in your main tank and it has a gauge (not very accurate but you get to know what it means) for the aux pump so you can manage your fuel well. My understanding for the gravity one is that you main tank shows full until the aux is empty and then starts to go down.
    I keep a cheap hand pump with a long bit of hose on each end in the car for an emergency in case of a failure. It would be huge PITA to transfer any quantity of fuel this way, but hopefully it would be enough to get out of strife.
    I have gravity feed and was originally concerned about knowing how much fuel I had, but the rear tank feeds to the main tank so as soon as the fuel gauge starts moving I know that I only have the main tank left. Works for me without the hassle of having to transfer fuel. Mate has a transfer pump and keeps on forgetting to turn the pump off if he is transferring fuel while travelling. I think you will get preferences both ways.
    Jul 2010
    Australia
    I have a Long Ranger Tank with a facet pump for 3 years now
    Done many river crossings, muddy bogs, Vic high country, desert etc without any problems.
    I carry a spare facet pump and an emergency siphon hose but never had to use them.
    You do forget to turn it off, but the there is a common filler hub for the 2 tanks, so it simply drains back into aux tank when the main one is full.
    You might run the battery flat if you forget to turn it off for too long
    You hear the....tick tick ...sound of the pump once you turn the engine off when you are outside.
    You do not hear it inside, soft noise.
    I like the idea of knowing how much fuel I have left
    regards
    GD-4
    Quote Originally Posted by go-disco4 View Post
    regards
    GD-4
    Mine is connected so it only runs when the ignition is turned on so it won't flatten the battery or keep running if (when) you forget to turn it off.
    NSW SW Slopes
    Is the pump accessible enough to replace? I'm tossing up between LRA and Long Ranger. The Long Ranger's pump looks difficult to access and has a tiny filter.
    Aug 2010
    I've got the Brown Davis, fitted myself with less than perfect fitting instructions.
    It has a pump too, not an issue since fitting.
    I'm not sure about the other brands but I have to remove to inner rear drivers side guard to get to the pump.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Dec 2009
    Ranelagh, Tasmania
    I had the Long Ranger (105l and electric transfer pump) on my D3 and now I have the Outback Accessories (92l and gravity) on my D4.
    The Long Ranger was totally reliable when I had it and the gauge is nice. Forgetting to turn the pump off was annoying.
    The Outback tank is a little smaller however it hasn't been a problem even with the V8, I think the transfer hose is a little exposed and would like to make a better guard. For me only having the gauge on the main tank is not really an issue as I reset trip A every time I fill up also my scanguage gives me an accurate distance to empty. The cars distance to empty is no longer accurate.
    The big advantage with the outback tank for me is cost and peace of mind, there is only one filler so it doesn't confuse people unfamiliar with the set up and there are no pumps or filters to fail. The tank was $600 cheaper than the others.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    NSW SW Slopes
    My indecision is due to not currently having a specific need although I'm sure that any of the tanks would be quite useful. The gravity feed single fill would be better suited to my everyday use whereas a larger capacity segregated tank better for remote area travel, not that I've done any in the D4 yet.
    IIRC the $600 savings for the OL tank was for a fitted tank whereas because I would fit one myself, the cost differences are only half that. As I intend to keep my D4 for a long time, the extra cost is not a consideration.
