Thread: Jate rings - bolts needed
    Feb 2014
    I have a couple of jate rings in the post, part ZXC9435 i.e, the slightly wider ones
    Unfortunately they do not come with bolts, they need 10mm by c.130mm long
    Any suggestions where in Sydney is best to get these, I'm assuming Bunnings is not going to cut the mustard.....
    I'm in Paddington, the nearer the better
    Simon
    Oct 2007
    Wantabadgery, N.S.W.
    Someone may come along with a better suggestion, but if you give these blokes a ring they might mail you what you want. They aren't close.
    Do you have the correct specs for those bolts? Are they high tensile?
    Bolts, Nuts, Screws, Tools from Nepean Boltmaster - Products & Services
    Don.
    Feb 2014
    So far as I can work out the bolts need to be 8.8, so high tensile, nyloc nuts.
    Nov 2012
    Acacia Ridge, QLD
    bolts High tensile.
    Hi Simon,
    Yep, grade 8.8 metric will be good for a recovery point. or metric 10.9.(20%stronger)
    If they prove hard to get you can use imperial, SAE bolts 3/8" , grade 8 or grade 9. I've found sometimes easier to use the imperial bolts because they're easier to find. Nylock nuts are a good idea. cheers simmo.
    Feb 2014
    To update I ended up getting the bolts from Bolts Nuts Screws Online, very helpful in sorting out what I needed
    If anyone looks to fit these Jate rings I found the 130mm bolts a touch short, 140mm much better. That was with the stock steering guard in place
    Apr 2013
    NSW, Sydney
    Try Welding supplies Silverwater
    Not used them, but thier website seems to suggest they fit the bill...
    Feb 2013
    st ives
    Quote Originally Posted by Simon View Post
    Bought set of the wider LR Jate rings ....( gawdaful expensive for a few peice of metal ) ...................want to source the bolts .....
    Does the length of a bolt include its head ....or just the shaft .....if it's just the shaft them 140 mm looks like it will be good but if the 140 mm includes the head. It might be a tad short ...........I am fitting the Jate rings through the same hole holding my TJM bar and the standard original steering guard to the chassis
    Many thanks
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    Jate Rings?
    What are they? Maybe I know them by a different name.
    Dec 2009
    Williamstown, Barossa, SA
    Quote Originally Posted by landoman View Post
    Many thanks
    140 is the length of the bolt not including the head.
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Dec 2009
    Quote Originally Posted by ramblingboy42 View Post
    Jate Rings?
    Here ya go...
