Thread: Grey Motor Conversion.
    Irymple, Victoria, Australia
    Who made the Holden grey motor conversions for Series one Land Rovers? I assume there were a few conversions available back in the day!
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Free Again Thanks Dan
    Quote Originally Posted by mick88 View Post
    Cheers, Mick.
    Grey motor is the same bell housing bolt pattern as the red motor , The only difference is the grey motor did not have side engine mounts it had a front mount under the timing cover and relied on the b/housing for support.
    But why would you want a 3 main bearing inferior 6 cyl motor
    Sep 2006
    Northern Beaches
    4 main bearings, not 3.
    Jeff
    Narre Warren South
    Dellow Conversions ?
    About | Dellow Conversions
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Quote Originally Posted by Jeff View Post
    Jeff
    I stand corrected , But still not a strong set up by any means for a six
    East-South-East Girt-By-Sea
    1.20 MB
    Actually I don't believe Dellow were around when people were doing the original grey motor conversions. Johnson's of Geelong were pretty much the original commercial manufacturer.
    The Johnson's manual is in the files section. http://www.aulro.com/afvb/local_link...id=7&linkid=53
    Quote Originally Posted by rangieman View Post
    But quite adequate for a low stressed, low compression engine such as this, with a design going back to the Chevrolet engine introduced about 1920.
    Automotive engines rarely had more than one main bearing every two throws until the 1970s - standard Landrover engines did not get a main bearing every throw until about 1980.
    There are other shortcomings of the Grey motor much more significant than this!
    Dont get me started . I cant stand the grey or red would not be worthy of a boat anchor
    Brisbane, Inner East.
    It gave illustrious service in many forms of motor sport when properly prepared. Fitting steel main bearing caps or steel strongbacks to the existing caps and the little engine would turn a reliable 7000 rpm plus. Most other shortcomings were in the breathing. The head was a motley arrangement of ports, three inlet and four exhaust. 200 hp on methanol blend was possible with Phil Irving's Repco Highpower head. With ongoing development over two decades Bill Kelly's Q7 speedway midget equalled this figure with a GM-H head but then Kelly is an exceptional talent.
    URSUSMAJOR
    Thanks!
    I don't, but just curious about who made the conversions as a friend has just purchased a 1955 Series one with a grey motor fitted. Obviously they did the job well enough and were a cheap reliable conversion at the time.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
