Results 1 to 9 of 9
Thread: Differential bearings
    May 2010
    Mindarie, Western Australia
    I'm trying to find the part number for the Timken crown wheel bearings but without any luck. Does anyone happen to know the part number?
    Gary
    May 2010
    I should have added 1996 model. About to install Ashcroft ATB's front and rear
    Gary
    The LR part number is RTC3095 for both front and rear diffs, 2- and 4- pin variants ...see Landrover Parts Catalog You can probably do a cross check with the Timken catalogue to pick up the Timken number.
    Jan 2012
    Bendigo
    LM102949/102910
    I got mine for about $25 each.
    Sent from my GT-I9305T using AULRO mobile app
    May 2010
    Quote Originally Posted by benji View Post
    LM102949/102910
    Benji
    Were you able to get them locally for that price or did you source them overseas?
    Gary
    Jan 2012
    Bendigo
    Just the local bearing shop (Bendigo bearings).
    That's the third set of carrier bearing I've bought from them now and they've always been in stock, so I assume they're a fairly common bearing.
    Feb 2010
    Townsville, QLD
    Check with Ashcroft that they don't come with bearings, mine did (locker, that is).
    May 2010
    Quote Originally Posted by Keithy P38 View Post
    Definitely no bearings. I've got them both in the garage ready for installation.
    Gary
    Yep, apparently used extensively also in Nissan and Toyota diffs...
