Results 1 to 4 of 4
Thread: Tracklog Format Conversion
    Normanhurst, NSW
    Seeking advice on how to convert tracklogs from *.gpx format to *.plt format.
    My new Garmin Map62s (replacing Garmin Map60csx) saves tracklogs in *.gpx format but Oziexplorer will only load *.plt formats - therefore need to convert.
    Roger
    Apr 2013
    NSW, Sydney
    Try gpsbabel, it seems to convert most everything to everything else.
    (Sorry on the train so I can't check it to confim myself)
    Jul 2009
    Hobart
    Hi,
    OziExplorer will import .gpx files in the desktop version. I think it is under the files menu. Then you can save it as .plt file
    Normanhurst, NSW
    Quote Originally Posted by austastar View Post
    Hi,
    Found it, just wasn't looking hard enough before.
    It's at the bottom of the 'Load' dropdown, titled 'Import GPX file'
    Strangely, 'Load Track from File (Multi)' has a dropdown box that includes GPX files but when I enabled that, it didn't recognise the stored GPX files.
    Anyway, all good now and thanks for the prompt responses.
    Roger
