Results 1 to 10 of 13
Thread: engines
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    engines
    bearing in mind that i have a 49 that i am going to rebuild
    and that i now have both types of 2 litre in my possession....
    would you rebuild using a siamese as it looks more like the 1600 or would you use a spreadbore because they are so much better than the siamese ?
    or would you try and swap both 2 litre engines for a 1600?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    JDNSW's Avatar
    Entirely up to you, and how close to original you want to get - and how much money and time you have!
    australia
    Quote Originally Posted by incisor View Post
    try ad go for the 49 engine spead bore far superier to siamese
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    May 2011
    North West Victoria
    Don't be too scared of a Siamese bore, rebuilt one over twenty years ago and they are fine. For the type of driving a restored 49 is likely to do, it won't your daily driver or be driven around Australia at highway speeds.
    At worst, you might have to change a head gasket (although I have never had to) and change the oil a bit more often, no big deal if you have completed a rebuild.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by russellrovers View Post
    want to swap me a complete 1600 for 2 complete 2ltr units ?
    Sep 2009
    This was discussed on the LRSOC site in the UK and they basically came up with what Heley said.
    Keep in mind though the spreadbore has a better oil filter system and a cheaper starter motor. The starter requires a modification to the bell housing to fit though as I am pretty sure as the starter bendix is longer so you may or may not want to do this.
    Paul
    australia
    hi why did landrover change to spread bore ???
    Russell Rovers
    Phone 0428732001
    JDNSW's Avatar
    The Siamese bore spacing was a necessary compromise when the bore was increased to raise the capacity to 2.0l, but experience with the engine showed cylinder wall scuffing due to poor cooling where the cylinders were joined when the engines were operated at sustained high rpm. Since this was not expected to happen with the Landrover, the engine was deemed satisfactory for that use.
    But they wanted to use the engine also in Rover cars, where it would be a problem, and the spread bore engine was developed to meet this requirement. This meant changing a lot more engine components however, so it took time. Obviously, as soon as this engine was in production it superseded the Siamese engine in Landrovers.
    85 county is offline AULRO Holiday Reward Points Winner!
    Sep 2010
    adelaide
    got me thinking, tuching liners
    400 chev, cummings 6 like what is in a 101 some where around here. cant think of any more
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    thanks all...
    will be going with the spreadbore unless i find issues with it.
    where is the best place to get a full gasket set for it?
