                                                3rd July 2014, 08:29 PM
			Low water alarm
					G'day guys my 99 td5 defender low water alarm has started to go on and off , not all the time been doing it last couple of times I drove it ( not a daily driver ) . Checked level  was all good oil normal , any ideas ? Is the sensor faulty ? Or something else ?
                                                3rd July 2014, 09:20 PM
					Mine did the same recently and then eventually came on permanently. Happened over about a month or so of being driven every few days or so on short trips.
 Turned out I had a small leak from the heater matrix (only 18mths old). I think it was leaking as it cooled and creating an airlock in the matrix.
 Id take the radiator plug out and check the level. If its down then top it up and start the hunt for a leak...
                                                4th July 2014, 04:03 PM
					Check for corrosion on terminals too, mine was doing the same, it was just dirty / corroded connector.
 ian
                                                4th July 2014, 05:48 PM
                                                #4
					Not sure of what type of sensor you have but we have a truck that has a single sensor into the hader tank. It probably needs to be changed every 3 or 4 years. Taking it out and cleaning it with a wire wheel can sometimes fix it for a while. Make sure you connectors are clean.
 Lindsay.
                                                4th July 2014, 05:52 PM
                                                #5
					I've also had the sketchy terminals.
 Also, I'm on rainwater so it goes off if the coolant is too dilute
Slunnie
 ~ Discovery II Td5 ~ Discovery 3dr V8 ~ Series IIa 6cyl ute ~  Series II V8 ute  ~ ~ Discovery II Td5 ~ Discovery 3dr V8 ~ Series IIa 6cyl ute ~  Series II V8 ute  ~
                                                4th July 2014, 07:19 PM
                                                #6
					I have an engine saver alarm , sensor in top hose as fitting instructions been in car for 3- 4 years no problems will check everything tomorrow thanks for the replies guys , Richard
