Results 1 to 10 of 16
Thread: Can You Tell Which Software Updates Are Applied and Does it Matter.
    Been reading a few threads where posters have said software updates have been applied to their vehicles to address various issues being experienced.
    At my last service I specifically asked the dealer to ensure all relevant software updates had been applied. On picking up the vehicle after the service the dealers says none were required - all software up to date. I asked the same question on my service 12 months previously - no software updates were applied at that service either.
    I now have a 3 year MY11 D4 which I suspect, software wise, is as it was delivered ex factory 3 years ago.
    1) Is there a list of software updates which are required?
    2) Can you tell which software updates have been applied, perhaps with domestic style electronic diagnostic tools - GAP IID tool (or other) for instance?
    3) Does it matter that some have software updates for specific issues they experience but other don't get the update because they have yet to experience the particular issue or complain about it?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Dealer told me they only apply changes when a problem occurs which sounds pretty silly to me coming from an IT background.
    Quote Originally Posted by geoz View Post
    ... sounds pretty silly to me coming from an IT background.
    Yep.
    1984 RRC, in hell
    I'm not too sure about that..
    I know plenty in IT that will patch security holes with vigour but when it comes to other updates, many adopt "it ain't broke" (except on their own systems)
    Feb 2012
    Wollongong
    Well ... It's not a PC and isn't connected to the web (I'd say most computer updates are security related bugfixes) ... so my inclination would be to leave it alone unless it has an actual malfunction or is the subject of an improvement campaign.
    In the last 4 years mine has only had one software update (updated compressor so new software) and one software change to modify functionally (IPC for clock in dash).
    Edit - beat me to it Tombie ! So my post could read "what he said" or "fools seldom differ" haha
    Oct 2003
    Montrose, Vic.
    Me three!....
    Coming from an IT background.... I still read carefully before applying patches... been bitten far too often in the past.
    Some patches are a no brainer.... but others, why would you if you don't have a problem to start with ?
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Adelaide SA
    The way I understand it, LR will only issue a software update to actually fix a fault, not just to make things "nicer" so to speak.
    I had an update done on the transmission, but I had to ask for it, and actually give them the technical bulletin. Their response was that this particular update was not issued as a "must do" if you like, but "if the customer is experiencing problems"
    So, essentially, if there are no reported issues, no updates will be done.
    The other way to look at it is, if it aint broke, dont fix it....
    Jul 2013
    West Pymble NSW
    Hi Basil,
    Slightly off topic but did your request for the transmission update improve things? I am thinking along the same lines and asked my independent to do this last time but they talked me out of it saying it wasn't needed. There is nothing majorly wrong with my transmission (and it's had the necessary service at 80k) but I wonder whether it should change a little more smoothly. An update can't hurt right?? If only to ease a curious mind??
    Matt
    Sep 2012
    With the transmission update, mine was done due to hesitation when you slow down, then suddenly need to take off, such as around a roundabout.
    The first update helped, but made for a rough down change, the second (and still current) is great. But if you didn't have the problem, the first update would have been a backward step, especially as at the time the second update wasn't available.
    NSW SW Slopes
    Quote Originally Posted by Bytemrk View Post
    It used to be referred to as 'the bleeding edge' when the latest updates were subsequently discovered to have their own bugs.
