Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: 3.5 v8 Dead - options
    Apr 2011
    Wandong,Victoria,Australia
    Unhappy 3.5 v8 Dead - options
    Hi All,
    Well my biggest fear has come true - the 3.5v8 in my 101 is officially dead.
    I had sent it back to the mechanics because it was running very poorly (no power, over heating, missing, etc).
    The diagnosis came back with the following compression test:
    1-40 3-75 5-95 7-75
    2-75 4-95 6-0 8-55
    The mechanic said that rebuilding the engine will not be a cheap option and that I should look at replacing the engine.
    I myself do not have the experience, knowledge or equipment to attempt an engine rebuild.
    And considering it is coming out of a 101 ambulance body - it's isn't going to be fun.
    So this leaves me at a cross road - and I would appreciate some advice from the brains trust on here.
    1) Should I replace the 3.5 - with a second hand unit (probably the cheapest option) ?
    2) Should I replace the 3.5 - with a re-conditioned unit from a Land Rover specialist ?
    3) Should I replace the 3.5 - with a 3.9, 4.0 or 4.6 ?
    4) Will a 3.9, 4.0 or 4.6 slot straight in? Will it fit in a 101? Is the block the same?
    5) Knowing that the later 3.5, 3.9, 4.0 & 4.6 had various forms of fuel injection/electronics, what is involved with removing the electronics and retro fitting the carbies from my existing 3.5?
    My problem is this - I do not have an unlimited budget. And I cannot do the work myself - so I will be outsourcing the project, which I expect will cost a bit of money on labour.
    If I had unlimited funds then I would put a diesel in it - but I simply do not have these funds available.
    I have seen 3.5 engines for about $1,000 - and been told that a new 4.6 could cost up to $8K....
    So I have to make some tough decisions:
    a) Buy second hand or new?
    b) Go for a 3.9, 4.0 or 4.6 - assuming that it will fit/work...
    Opinions? Ideas?
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Crafers West South Australia
    A second hand running 3.5 should cost you a small number of $hundreds at most and it could run for many years yet. For example, I'm wrecking an '89 RRC, and at around 300,000km old the engine runs fine. They are the slowest yet longest lived version of the LRV8 and therefore often end up stashed at the back of a shed when the car around it falls to bits. All the other versions are more stressed and prone to early failure and should be thoroughly reconditioned unless proven to be very low mileage.
    As for exterior engine bits, everything off your 3.5 should bolt up to any donor V8 engine.
    May 2003
    On The Road
    Earth to Bacicat!
    Jan 2008
    Nowra NSW
    The safest and best bang for your dollar is another 3.5 rover V8.
    Reconditioned with the cam shaft and timing chain up grades would even be better.
    The Bigger rover V8s will swap over without too much trouble, if you stick with carburettors, but you will need the services of a good mechanic to reset the jet and needle in the carburettors to suit the bigger capacity motor.
    Next up on the cost of things is fuel injection on the later rover V8s fitted to The 101 which requires extensive wiring up grades and cost due to the fact the 101 was never designed for EFI.
    If you are not mechanically minded and poor.........finding another 3.5 rover V8 is not hard , but finding one with a good or proven history is hard as they are now a very old motor.......profestionally reconditioned one is the safe option and do all the unbolting and bolting up work your self will save money and the parts will swap over from one motor to another.
    Just remember the standard 101 engine oil pump and oil cooler set up if it is still fitted to your 101 is hard to prime for a new or reco engine start and some people fill the 101 oil pump with thin grease or thick oil for easy new engine oil pressure priming.
    When you get into the job of removing the motor from a 101 it is straight forward job as it is a big Meccano set and access comes easier.
    Doors and seats are removed easily etc.
    Dec 2009
    Williamstown, Barossa, SA
    Hi GG. Not good news! But... I have a 3.9 V8 in the shed which I've had in mine and is known to be good. It does not belong to me, but I'll txt the owner and c what he wants for it if you like. Its already set up for a 101 with carbs, has the gear lever pilar on it etc etc. I will txt him and PM you back! . I can see a tutorial engine change happening at Wombat.....
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Logan Village area S.E. QLD
    Not good to hear Can't offer any suggestions. We hope everything turns out the best for you.
    Series Landy Rescue
    Our FB Page..
    Western Victoria
    A 3.5 will cost about $8k to rebuild.
    You might consider looking for a Range Rover Classic to wreck. That way you can test the motor before you buy.
    A thought would be to host a BBQ or two.
    Engine removal day and engine replacement day.
    Oh, have a chat with Lardy. He replaced the motor in his ambo recently.
    Western Victoria
    Quote Originally Posted by Sitec View Post
    Yay!
    GG, road trip.
    Aug 2010
    Sunbury, VIC
    Earth to Bacicat!
    Spoken to GG at length about this. I do have an old 3.5 in the shed, but it is far from healthy which is why I pulled it out in the first place. I am quite shocked that the engine is knackered as it drove so well on the way back from Canberra. As much as I hate to say it, I'm wondering if the PO knew about this and tried to cover it up.
    Quote Originally Posted by Mick_Marsh View Post
    It would be good to know how Lardy did it, as it looks like a **** of a job to do. Not sure if it can be done in a driveway yet - it almost looks like it has to be dropped out the bottom. Without either tearing up all the floors - not easy in this unit as there is cabinets, etc over parts of the access covers, or lifting the whole body off.
    As always though, if there is anything I can do, I am happy to help out. If it can be DIY'ed, then I'm willing to give it a shot.
    Jan 2014
    PNG
    You guys are amazing, all,this support in a few hours, I dips my lid to you all.
    apologies to Socrates
    Clancy MY15 110 Defender
