Results 1 to 4 of 4
Thread: Salisbury pinion seal leak
    Nov 2012
    Acacia Ridge, QLD
    Question Salisbury pinion seal leak
    has anyone changed a pinion seal on a salisbury diff, recently, is it difficult to do at home? I have an electric rattle gun.
    simmo
    95 300Tdi Defender wagon
    Geelong, VIC
    Must be pinion seal day today
    Check out Devan's post from earlier today.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    I haven't but I do have the correct LR tool for driving in the new seal.
    Nov 2012
    Acacia Ridge, QLD
    Thumbs up seal changed ok
    Thanks all, for your advice, I changed the seal OK and did the nut up to the same place . I drove the new seal in with the old seal. It's best to smear it with silicon blue on the metal mounting surface before you drive it in to stop leaks.
    simmo
