It should be easy to recon with a kit for the solenoid. What engine is it?
I did mine on my td5 with a denso kit for about $40 and it can be done without taking the starter off although it is easier to remove it.
If it's a td5 also check the condition of you fuel pressure regulator as when the get tired the leak onto the starter accelerating their deterioration.
