I cannot directly answer your question but I am curious how a misadjusted timing belt would cause the cam chain to break/cause damage and go through the engine.
I I thought you were going to say that the overtightened timing belt caused the oil pump housing to fail causing the engine to fail due to a lack of oil.
When belts are changed these days it is good practice to upgrade the oil pump housing to a later stronger version.
Major servicing on the engine is done every 7 years or 160,000km where the belts are changed - so the new engine is well within the this. If it has done 80,000km of trouble free motoring then as long as the basic services have been done you should be right.
