Well BusinessConnected, my engine woes led me to explore a similar path.
You may find that the Ford Territory does indeed fit however my own checking revealed the following:
1. The Ford engine was a LOT cheaper.
2. The Ford engine warranty would not extend to use in a Disco 3.
3. Land Rover would fit the Ford engine but would not warrant it either.
In the end I opted for a complete (not really) engine fitted by an independent LR enthusiast organisation. Saved heaps on the quote that LR dealers 'offered' but still purchased new bits including a turbo and other ancillaries. My alternator was only 7 months old after having been replaced so was used. Yours may be fine.
In Melbourne there will be LR independents (that others from this forum would recommend from personal experience) so that would be my first port of call. They would supply the lot including engine and needed bits and more than likely offer a discount on parts due to the sheer size of the project. BTW, if you don't already realise, it's a body off job.
My total cost was $21 410 but that cost included an opportune upgrade to the latest EAS compressor as I feared it would be the next item to fail inexplicably.
If you go the brand new engine route you may consider the total cost and weigh that up against the market value of your vehicle. I chose to proceed based on the fact that I love the ride, comfort and capability of the D3 and that with the new engine I should get at least another 7 years of enjoyable motoring...
HTH in your decision-making process.
