Results 1 to 10 of 11
Thread: Bullbar underbody protection
    Jan 2013
    Baulkham Hills
    I am considering a bul!bar / winch for my 2.7 D4 currently a name like arb or opposite lock. At the same time I am planning for underbody protection.
    Any current bullbar owners like to comment on what underbody protection is needed compatible with bar?
    Main concern is intercooler and radiator damage, rock sliders maybe.
    Main need is a robust tourer with a trip up the cape next year the biggest challenge.
    I think I can help you there
    If I get out early enough (and it's light still) will try to get some pics...
    Jul 2009
    If you fit a ARB or OL bar then you get plenty of great underbody protection back to the OEM steel plate that covers the sump etc.
    Yes you can get a protection plate for the auto and nearly everything else you can think off if you really want to, but in my opinion most are serious overkill other than the compressor protection plate that Gordon (GOE) sells.
    Add in a good set of rock sliders and you have most everything you need covered.
    The first thing that usually gets flattened is the dual exhaust pipes that go under the diff, but I had mine replaced by the local exhaust shop for, from memory, $120, so that's no big deal.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    I make a replacement heavy-duty plate for the underside of the ARB bar, will consider one for an OL bar if there's the demand.
    Gordon
    I've had the opportunity to test my clearance and can say without the protection I would have done some much more serious damage.
    I'm plated from the bar back to the back of the TCase and then under the tank as well - I really mashed that up!
    Attachment 80444
    Attachment 80445
    Attachment 80446
    I then added some sliders
    Attachment 80447
    Next will be compressor guard, air tank guard, Arm sliders and rear diff guard.
    Aug 2010
    Tombie how much was the Ironman Engine / Transmission protection plate kit?
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    $450
    Apr 2013
    Hi Tombie, where did you get the fuel tank cover from? Was it a custom job?
    Devon 4x4 - the freight was more than the plate
