Results 1 to 10 of 12
Thread: LED light bar in place of spotties
    St Helena,Melbourne
    4.28 MB
    Looking at an LED light and wish to mount it using the 2 spotty tabs on the bar instead of mounting on top of the bullbar top bar, anyone have them mounted like this ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2012
    Orange, NSW
    Closest I've seen was a guy with a 76 who'd used the aerial mounts but underneath the bar so it was upside down.
    Looked decent.
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Free Again Thanks Dan
    You will find the led bar will no way match the distance from a pair of decent spotties.
    I have a 42" 240w led bar up on the roof rack and a set of ipf xtreme ,s with 70w hid on the bar .
    The spotties light up down the road a decent distance and the led bar lights up from the front doors out to the sides and forward
    May 2006
    Woolgoolga
    What light bar is it chris?
    Spread, spot or combo?
    Quote Originally Posted by Vern View Post
    Combo one of murrys
    Dont get me wrong i love the led bar but every led bar ive seen is no match for distance to a set of decent spotties
    St Helena,Melbourne
    4.28 MB
    I currently dont have any so anything will be an improvement, i do have a pair of IPF's that i'm getting around to fitting .
    1974 VW Kombi bus
    Hid in the spotties and led for that instant brightness You wont reget it
    Feb 2005
    I have never really got the need to see a kilometre down the road........my eyesight just isn't good enough to see a roo at 1km
    I never had spotties fitted until a few years ago when a guy at work had a set of rallies going cheap. OK light but rarely used.
    I have recently fitted a Rijidij bar with a 100w combo light bar, it puts out good light to the sides and enough out the front to pull up in time if a roo jumps out. Cheep compared to a set of FYRLYT's which I fit to the work utes. I have only really used it once at night for 50 or so km, the reflection from the road signs can be a pain. The other think I like is my radiator is open more than when a big set of spotties are sitting out front.
    I have been travelling with work a bit which means being on country roads from 5am......I only see the roos when they are a couple of hundreds meters in front at the most (hilly windy roads) and have avoided them every time.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by rangieman View Post
    You talked me into it Chris, bought a HID kit off ebay that i should get in the next day or 2. Decided i may as well use lights i have and can add a led bar later if i need to.
    1974 VW Kombi bus
