Results 1 to 10 of 19
Thread: Rimmer Bros Brake kit question
    Apr 2014
    Australia
    Hi All
    I want to replace all my brake pipes and want to know if the Rimmer Bros product from the UK is what I should be ordering, or does anyone know of another supplier who can supply me the full brake pipe kit all the way from the brakes to the master cylinder
    I have a 1977 S3 SWB RHD 2.25 Petrol Landy
    Craig
    Aug 2012
    Adelaide
    i've been looking at:
    [ame=http://www.ebay.com.au/itm/Automec-Copper-Nickel-Brake-Line-Kit-Land-Rover-Series-3-SWB-RHD-Dual-to1980-/360695349765?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item53fb1e4205]Automec Copper Nickel Brake Line KIT FOR Land Rover Series 3 SWB RHD Dual TO1980 | eBay[/ame]
    obviously for my swb.... but he has different kits.
    East-South-East Girt-By-Sea
    1.20 MB
    Be aware that in Australia a roadworthy inspector may reject copper or copper nickel brake pipes.
    Apr 2014
    Australia
    Hi ... Thanks guys
    The Automac Brake kits are copper .... So I am assuming they should do the trick ?
    Apr 2002
    Bellara 4507
    32.43 MB
    got copper nickel on mine and you would be hard pressed to pick it wasnt steel looking at it...
    and it wasnt picked up on at all.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Themadmob View Post
    Hi ... Thanks guys
    No, straight copper is out. The copper/nickel alloy ones are the go. There has been some debate about this recently on another thread but I think the copper nickel alloy is okay.
    Apr 2014
    Australia
    Great , Thanks, Gotta love the help on the Forum :-)
    1.20 MB
    Quote Originally Posted by incisor View Post
    I purchased a roll of Copper-Nickel tube branded as brake tube from my local BrakePro in Nowra, however since that time I was informed by a NSW Blue Slip Inspector that any form of copper is not acceptable.
    Whether its after a particular date I'm not sure. It's just a warning that there may be problems.
    For the defender I'm going to play it safe and purchase lengths of bundy tube for the job.
    Apr 2014
    Australia
    what about the "ends"? screw threads ... can you purchase them locally as well?
    1.20 MB
    Yes you can buy them from most specialist brake services.
    Be aware that most modern Land Rovers will have metric flare nuts, while most SIII will have UNF so be carefull the new ones match the ones you are removing.
    Also Land Rovers use a double flare on the brake pipe.
