I agree that this would be useful, particularly with suspension and total body heights of a "standard" vehicle. I'd probably make a small sticker to put on the inside of the visor, or similar.
Hi, just wondered if anyone has ever come up with a simple to understand settings guide?
Although the instructions that come with the unit are clear, it may be easier to have a simple quick reference guide..
So if the car controls are "A" access mode "N" normal mode "O" off road and the Llams are "-1" "0" "1" "2" "3" "R" (I understand the red button can be used for some settings..)
What do the different combinations give you
Eg
"N-1" normal road height -30mm.. Good for highway, same setting from LR as if going over 160kph
"N0" normal road height... Factory standard as set by LR
"N1" normal road height plus 30mm.. No speed restrictions, good for off-road corrugations,
It would be great if someone could come up with a complete list of combinations that could be put in a simple quick ref guide for the new Llams user..
Just a thought :-)
Regards, Will
LLAMS, FYRLYTS, OL D4 Bar
Here's my thoughts on this, once we install ours, I will be using it this way.
I have no use for the lowered setting so I will only be using the Plus 30 and plus 50
Set plus 30 for all offroad, just set it and select a mode.
Plus 50 will only be used for deep water crossings.
If you keep fiddling with it, you run the risk of over heating the compressor, so for me, set it and forget it.
Baz.
Cheers Baz.
2007 BMW R1200GS
Redback and others, you need to be aware that it is not quite as simple as setting and forgetting. The main problem / challenge, which catches me out all the time, is that the car sets it own off road height automatically every time you change terrain settings. If you don't realise that this has happened (nearly every time for me!) you then get off road height plus Llams height and only pick it up when the suspension starts behaving like a Jeep with limited downward extension and lots of thumping.
I now use the car's own settings most of the time and only use Llams when doing long high speed runs on sand or when I want extra height above off road height for some reason, such as water crossings.
Just another thing to consider.
Bob
Why don't you want to use the lowered setting - certainly not a lot of use offroad but is great for normal every day use - ride is not compromised and easy to get in and out of the car.
I would reinforce your comment about not fiddling with it - pick your height and leave it there and save your compressor.
For me - onroad is set at onroad and LLAMS at -20.
Offroad - set at onroad and LLAMs set at +50 so you have the equivalent of normal offroad height - it stays there except:
If I come across a very tight bit offroad - I go to offroad with LLAMs still at +50 and this is good enough for most tight tuff - you still have on height to go in the system - the usual auto extended if you get caught up (with LLAMs at +50 you are the equivalent of super extended).
After the hard stuff is cleared back to onroad and LLAMs +50.
I find this minimises lift changes and is still OK on suspension and CVs etc. Be aware that the CVs are most vulnerable at high heights when power and lock is required - softly softly is the way to go in this scenario.
Cheers Baz.
2007 BMW R1200GS
Baz,
You are very lucky to have such uniform conditions. We often have sand then roads then sand then rocks then get stuck and use RockCrawl to get out etc etc. You turn your engine off for some reason and everything except Llams is reset and so on. I often get caught out.
Bob
My thoughts, not that my vehicle sees much other than a bumpy track...
if clambering over rocks is involved then leave Llams off except when needed in addition to off-road height,
if cruising tracks then use Llams +30 or +50 as applicable,
If sneaking under a fallen tree then access height +(-) Llams extra low (bump-stops) providing there are no rocks on the track!
Graeme has just about nailed it.
Common sense will normally see you through.
BTW some D3's only can get -20 not -30/35 as with the latter models. ( Apart from if you use the special functions button)
The only exception is perhaps we should post the 'expected' heights with standard tyres when using each setting, this would be useful for entering carparks.
But as always Buyer Beware, each vehicle may calibrate slightly different and you should measure your own vehicle to be more accurate.
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
And focus! Pay attention to your systems as well as the track![]()
