Do you have a sunroof? If so the water is probably the result of a blocked drain.
I had the same problem with my D3 and found it always occurred after the car was left out in the rain and then would come good after a week or so. I re-soldered the connection that you did and cleared the blockage from the sun roof drain which resolved all the problems.
