Results 1 to 10 of 18
Thread: 2013 Discovery 4 Speedo KLMS-Miles
    DMPerth Guest
    Hi All,
    I am taking my Discovery 4 overseas touring and want to have the speedo changed from KM to Miles. Currently I can choose either option in the computer menu but only for the trip computer, not the Speedo. If an overseas dealer can change this, is it a simple case of a plug in and change as I want to (obviously) avoid changing the dash fascia over etc.... Thanks.
    Williams West Aust
    Welcome aboard.
    This post will get shifted to the D3/D4 area,more chance of an answer there.
    ENJOY
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    How many countries still use MPH? Won't most countries through which you will travel have the metric system?
    It really is easy to just use km/h. There are only a few speeds you have to remember.
    Jan 2014
    Quote Originally Posted by DMPerth View Post
    Hi All,
    Depending on where you're going, leave it the way it is. Europe is metric, the UK isn't & the US isn't either...so where are you going?
    May 2014
    Point Cook, VIC
    Get a smart phone with GPS, a windscreen mount, and then download a Speedo app, and you can change between MPH and KPH as required.
    Sounds like you are planning a great trip.
    Oct 2003
    Montrose, Vic.
    When I look on Topix at the build details of my car, it specifies "KPH SPEEDOMETER"... so I suspect its not a simple dealer change.
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Apr 2011
    Austin, TX, US
    Where you heading?
    The US is MPH Still. The Speedometer on my D3 has both on it. Maybe there is an option like that for your D4? Overall it should not be too complicated as speeds here are fairly standard with a few exceptions. Small communities and town are 30-35MPH, Highways generally run 45-55 and interstates generally run 60-65. Texas is the home to the fastest road in the nation, 85MPH, which is too fast for many of the junk vehicles that drive on it, which can make it dangerous.
    The Part number, I think for the LR4 MPH Speedo cluster is LR027891
    An [ame="http://www.ebay.com/itm/LAND-ROVER-INSTRUMENT-CLUSTER-LR4-RANGE-ROVER-SPORT-LR027891-SPEEDOMETER-/261053786137"]ebay US link[/ame] with a picture of the unit.
    [ame="http://www.ebay.com/itm/LAND-ROVER-INSTRUMENT-CLUSTER-LR4-RANGE-ROVER-SPORT-LR027891-SPEEDOMETER-/261053786137"][/ame]
    Jan 2013
    Adelaide
    I've seen obd 2 head up speedometers on eBay as well - might work for you?
    O and I think relying on a conversion chart or memory of speed limits is too hard. In the US you may see any speed limit in 5 mph increments from 25 to 80 mph. You already have enough to think about driving and navigating in a different country ( possibly on the other side of the road).
    JUst divide by 8 and multiply by 5.
    Quote Originally Posted by clubagreenie View Post
    Or put some thin coloured tape on the speedo to indicate key speeds.
