Results 1 to 2 of 2
Thread: Battery When parked up .
    Mar 2012
    Gabbadah WA
    If vehicle is left secure in a locked up shed , will the vehicle chew up more battery power to maintain things when vehicle is locked ? or will it be better for the battery if vehicle is left unlocked etc .? Or does it make little difference .
    Jul 2011
    Toowoomba
    Once it's sleeping ...
    Hi Fatso,
    It uses the same power.
    The best answer is that you should lower the Car to Access Height. It normally "wakes Up" & levels the Car when turned off.
    After that it's just sleeping. ( provided you don't have any faults)
    Richard
