G'day Rosco, Sounds like you have a few cable wraps jammed up at one end of the winch. This does happen if you are pulling from one side or not feeding it evenly onto the spool. As they do not have a levelwind you have to watch it feeding on and try to ensure it doesn't bunch up at one end by pulling sidewards on the cable as it sounds like has happened with yours. Was it that tight that the clutch was slipping ( you would hear a loud clacking noise if it was). It is unlikely that you will be able to pull the cable out by hand if this has happened. Easiest way to fix it is tie the rope off to a tree or something heavy (another vehicle etc), engage the winch, put the transfer case in low range, select reverse gear and engage the pto. Let the clutch out slowly and as you reverse it should feed out while keeping tension on the cable. That ought to fix it.
Cheers......Brian
1985 110 V8 County
