Thread: windows 8 screen saver
    Sussex Inlet. N.S.W.
    Somehow my screen saver (usually blank) has changed to rainbow colours. No matter ha I try to get it back to blank it won't change. I go into "personalisation" and set it to BLANK but it won't budge. How do I change it? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Adelaide Hills - SA
    Is it a legit registered copy of Win8? If it hasn't been authorised/authenticated back to MS then you can't personalise it, and you get the dud rainbow screen saver by default.
    If it is authorised then I dunno !!
    Edit: to say that if you have done major hardware changes (like new motherboard/etc) they you have to re-authenticate
    May 2003
    On The Road
    I ended up using the "Desktop Background" option for a "screen saver"
    May 2003
    On The Road
    sorry but,
    you have a blank screensaver?
    (I realise LED's dont really need one--)
    Windows 8 was installed when I bought the computer. No program changes either. It just appeared. There is a choice of BLANK for a screen saver which means the screen is plain black.
    Jim VK2MAD
    '17 Isuzu D-Max
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    you are up to date with all the windows updates?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    All up to date. If I have misled everyone it now appears not to be a screen saver problem but what happens when the computer goes into hibernation, which is a low power mode. Can't find any settings to change for this. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    control panel > power options
    on the left should be menu options that allow you to change what a lot of stuff does...
    i just put mine in high performance mode and it turns all the stuff i dont want off by default
    Still doing it in high performance mode. What is actually happening is that it goes to the screen saver ok. Then to hibernation. When I wake it it goes to this rainbow screen instead of my desktop, which it used to go to. I then click on the rainbow screen and my desktop then opens normally. It appears to be this extra step but I don't know how it got there, how to remove it or to what part of the program it belongs. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by jx2mad View Post
    time to use the menu options on the left
    mainly the bottom two i would think
