Results 1 to 10 of 13
Thread: Puma Glow Plugs
    Puma Glow Plugs
    Hi All,
    My 2009 2.4 puma is back from service and I have been advised that the rough idle at start up and white smoke is due to a failed glow plug.
    I know these are the symptoms that can be associated with bad glow plug/s. My question is have any others had this issue? 110,000km.
    G
    Oct 2007
    I haven't had it myself. I could be wrong, but it doesn't sound like a glow plug to me. Once the engine fires, cylinder compression and idle revs should have all cylinders firing properly.
    An injector could have a problem, or something causing weak compression in that cylinder will cause white smoke cold. Does the smoke disappear quickly as it warms up?
    glow
    reading the manual. the glow plugs have 2 modes. one is to glow and allow easier starting and thern there is the afterglow that goes for 30 seconds after start to make the car run and idle smoothly. the smoke literally only lasts 10 seconds maybe 15. it is unburnt fuel by the smell. as soon as it is just off cold it runs smoothly as usual with no smoke.
    n plus one Guest
    Quote Originally Posted by quaddrive View Post
    Hi All,
    G
    I'm the same year and mileage - haven't had this problem (yet).
    FWIW your symptoms mirror that which my mate with a 76 LC experienced when one of his glow plugs packed it in.
    Oct 2007
    What sort of ambient temps are you experiencing, Quaddrive?
    As a point for comparison, we've had 3-4C locally, and mine (2007 Puma, 250,000+ kms) will still start cleanly without any glow...just takes a few more cranks, but even firing and no smoke. I hardly ever use glow, since it starts so quickly, and you don't get that "rich fuel rattle" first up. But if it takes longer than about 2 seconds, I prefer to glow.
    Hopefully nothing serious with yours...good luck.
    Jul 2012
    midwest W.A
    Quote Originally Posted by Brid View Post
    Yep, you're wrong Brid, If an injector was faulty, the miss would be constant (even after warm up). Not to mention fault codes and malfunction indicator lamp.
    Faulty glow plug symptoms (white smoke, rough running) would take a few minutes to clear.
    Jan 2010
    Cashmere, QLD
    Smile Rough Idle when cold.
    I am just starting to have this problem now. 2008 SVX 180000Ks, Removed and cleaned EGR. Still doing it.
    I will check the GPs next.
    Might have done something during the high pressure clean under the bonnet a couple of weeks ago.
    glow plugs
    Interesting how things pan out.
    I ordered in the glow plugs. By the time they arrived the issue had gone away. I had checked the relay, wiring harness etc for the glow plugs and all looked good. It just started to run perfectly again. I still have the glow plugs sitting in the spares cupboard in the shed. I think it must have been an electrical issue, bad earth or something. I must admit it does not inspire you with confidence in the thing though!
    Giles
    Jul 2012
    ferntree gully australia
    Giles
    Hi Giles , those intermittent problems are the worst ones to have , because you're thinking will It come back ? lets hope not and It was just a gremlin that's gone !!.. good luck . Jim
    Nov 2013
    Barwon Heads - Victoria
    Giles
    Hi Giles,
    I too have been experiencing a very rough idle from cold start and white smoke this week in my 08' 110 150,000 km's, as the engine warms up it goes away which makes me suspect glow plugs too. I have visually checked the fuses, relay and plugs and all seem OK so it's time to get some plugs.
    Have you had the issue come back?
    There doesn't seem to by many listings for Puma glow plugs, am i right in assuming that Transit 2.4 plugs are the same?
    Regards,
    Lachlan
