So, connecting the plugs just follow the instructions with the pack.
I drilled 2 holes in the die cast box, inserted grommets and fed the cable through,then cut open the insulation on the white (earth), yellow (left turn) green (right turn)
I soldered one end of the resistor to the white earth and attached the 2 diodes to the other end. Then soldered one diode to the green and one to the yellow (as per the diagram.
I attached the resistor to the lid of the box, then used heat shrink and tape to protect the joins
Then sealed everything up and attached a strap so I can attach to my trailer when in use
It all works great
regards Paul
D4 2.7litre
