4th August 2014, 11:27 AM
Struck another hurdle
I was changing the vac hoses on my cruise this morning. I wanted to take of the panel underneath the steering column when lo and behold the plastic caps that have to be taken off have been glued on.
I pried them of and some blue glue has been stuck to them. I cant see if they are bolts are screws to take the panel off. I was trying to replace the long hose but cant get the panel off.
Any ideas as to what to do and, is this normal.
4th August 2014, 12:13 PM
If it's the one I am thinking of it's held up by 4 screws two either side top and bottom.....maybe they have glued covers for the screws?....post a pic derpomz it would be helpful.
4th August 2014, 01:03 PM
cross head screw heads if original, I have encountered 8mm ( I think ) hex heads. They are never very tight, should be a very easy task to get that panel off. The finishing covers over the screws should pop off exposing the screw heads
4th August 2014, 02:01 PM
#4
I've yet to see a P38 with those caps still in place.
4th August 2014, 02:43 PM
#5
That's why I thought the PO may have glued them in
4th August 2014, 03:22 PM
#6
I have two of the four caps held on with bluetac. Can anybody beat two?
4th August 2014, 03:31 PM
#7
Rounded out to an even zero. I got rid of them long ago.
Gary
4th August 2014, 04:03 PM
#8
I have two of them somewhere, the centre console I think
Steve
4th August 2014, 04:11 PM
#9
2 and three quarters of them left here
4th August 2014, 04:27 PM
#10
Pete38 is winning. You can buy them, but I haven't given it would stand me close to $100.
