Results 1 to 10 of 11
Thread: Heater hoses, thor
    Feb 2013
    Gosford, NSW, Australia
    Heater hoses, thor
    About 18 months ago I replaced the heater hoses, I can't remember what brand but it looks like it was a cheap one.
    The hoses are now rock hard and need replacing.
    My question is has anyone replaced these with some 20mm heater hose?
    The original hoses have a bend in them, presumably to help with movement between the engine and the firewall, but mine are not moving at all.
    So can anyone think of any issues which might arise?
    Steve
    Jan 2012
    Bendigo
    I can't see why this wouldn't work. I did the same on my gems quite successfully; it was like that for almost 3 years.
    However, after the last rebuild I put bearmach and genuine hoses on, and the quality of these was a lot better than generic dayco heater hose.
    Sent from my GT-I9305T using AULRO mobile app
    Feb 2013
    I am thinking some silcone hose may be the way to go it has plenty of flex
    Steve
    Feb 2013
    The hoses are not the same diameter at each end, so standard hose may be problematic.
    The pricing is £2 for britpart and allmakes and £23 for genuine
    After some more searching I came across these URO ones from the US, they appear to be properly molded to a larger size on one end about $35 for a pair landed in oz
    [ame=http://www.ebay.com.au/itm/161359885866]Land Rover Heater Hose PCH118830 | eBay[/ame]
    Steve
    Jul 2014
    Steve those URO sound good, unfortunately I didn't receive your download could you give me the URL to check it out please?
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Feb 2013
    eBay now has the annoying habit of posting a link to some kind of embedded app instead of the item page
    It's item # 161359885866 - just stick that in the search box
    Steve
    Jul 2014
    It looks good and reasonably priced....thnx
    1974 xj6l jaguar
    Feb 2013
    I now have a heater bypass in place in the coldest week we have seen for a while
    Hopefully my new hoses will arrive post haste !
    In the true style of a British Car with a French heating system owned by Germans I can now report that the outlets from the heater are 22mm (7/8" actually) and the outlets from the engine are 19mm (3/4").
    So standard heater hose is tricky to use, if you can even find 22mm stuff without going to a specialist supplier.
    On the upside my cooling system now seems much happier without the slow leak!
    Steve
    Quote Originally Posted by SteveFarmer View Post
    Etc.........
    Steve
    Isn't that called the "Deefer" option?
    Feb 2013
    Well I now have a couple of pretty good looking heater hoses in my possession, it just a pity I don't have a P38 to fit them to
    Steve
