Fuse 15 does the LH Tail light as well, so you'll have to pull that bulb too. Yes, the licence plate light is normally on this circuit. One other thing to check; this circuit provides the illumination signal to the stereo - if it has been butchered that might be your problem.
You're lucky it isn't fuse 16 - that does much more!
 ), but I am not as happy as I should be.
