Results 1 to 9 of 9
Thread: Bolt Patterns of Various Rated Electric Winches
    Jun 2013
    Warner Area - SEQ
    Question Bolt Patterns of Various Rated Electric Winches
    Guys....
    Just wondering about installing a Electric Winch on my Disco..... Is the Stud Bolt Pattern exactly the SAME independent of the SIZE of the Electric Winch? Looking at installing a 12,000lb winch BUT I also wanting to install a smaller (6000 > 9000lb) Winch into my Toy Zook due to the limited room to mount it. It got me thinking as to whether there is a standard bolt template no matter what the winch size is ??
    Any help/advice would be appreciated
    Rob
    Avoca Beach
    Most winches have a standard bolt pattern.
    BUT several winches have different dimensions.
    For example the Kingone winches have a longer gearbox as the brake is on the end.
    12,000Lb winches are often bigger than 10,000lb winches as the motor can be longer , although Kingone just have diferent gearing.
    So get the measurements before you start.
    Another thing to look at is the position of the slot in the bullbar.
    Some bullbars , particularly bullbars that have a front mount rather than bottom, need an offset fairlead for Dyneema eg ARB for Ford Ranger.
    You would not believe the variations by car by bullbar brand. When I sold winches the customers often expected you to know every variation, but when you would call the importer they would say Duhhh? Dunno!
    Regards Philip A
    Jun 2013
    Warner Area - SEQ
    Question
    Thanks Philip,
    I've removed the 12,000lb winch the ute I'm selling and hope to install it in my new Disco. The B/Bar is a Alloy TJM Winch bar I believe, but looking at it I will still need to make up a Steel mounting plate that will also bolt to the mounting brackets for added strength....
    My zook is a different in the fact that the B/bar is not a winch bar and therefore I've got to cut it to get the winch in to start with then also make up a steel mounting bracket..... but I was sort of hoping that say a 6000lb > 7500lb winch maybe slightly smaller in width at least which would enable less mods to the B/bar to get it in....
    rob
    Regards Philip A
    Apr 2011
    Dungowan
    Good luck getting anything but a small framed winch (6000lb Warn??) to fit in the bulbar on the Suzi. Mind had a 9500lb Premier, that's now on my Disco, mounted above the chassis rail height in a tube bar.
    Jun 2013
    Warner Area - SEQ
    So, would a 6000lb have a smaller mounting dimensions then ??
    rob
    Apr 2011
    Dungowan
    From memory, the 6000 has the standard 10" x 4.5" mounting bolt pattern. Overall winch dimensions vary tho.
    Its the length and diameter that will be the killer with the Suzuki.
    Avoca Beach
    You can get small sized 'rock crawler" winches but they don't take much rope.
    Regards Philip A
    Apr 2011
    Dungowan
    Thats an option for a Suzuki, and carry a couple of extension straps.
    The 9000lb work well on mine, but its size had it sitting in front of the grill and nil chance of it fitting any factory made bar for a Suzuki without major surgery. No so good if your after a more discrete fitment.
    The ARB winch bar for the Sierra was suppose to be able to take a M6000 Warn, but no bigger.
    I would also look carefully at the bar mountings if using anything bigger than a 6000lb, there is not a lot attaching them, 4 x 3/8" bolts from memory.
    Jun 2013
    Warner Area - SEQ
    Cool
    Thanks Rick....
    My Zook is a '93 LWB Vitara which I've modified quite a bit and is the vehicle I use when I want to go and do a bit of hard playing in the bush where I'm not overly worried about scratches, small dents, etc.... but w/o having a winch, I'm a little bit more cautious when doing mid-week solo outings as to where I go....Hand winching is just not that appealing.....
    Quote Originally Posted by Rick1970 View Post
