Results 1 to 3 of 3
Thread: Diff/ Axle commonality
    Feb 2010
    I have a Heavy Duty off road trailer using the rear chassis and axle/ suspension from an '88 RR rear.
    Question
    Will a D2 Diff/ Axle assembly complete replace the existing? This would be an easy engineer solution to update to D2 Hubs.
    I suspect not. Any easy solution?
    Alternatively what about a D1 assembly? are the dimensions of trailing arms and shock mounts the same?
    How can I otherwise convert to D2 stud pattern.
    St Helena,Melbourne
    4.28 MB
    You could adapt a D2 axle to fit by altering the mounts or just use a standard trailer axle with commodore hubs ( slight mods required to fit D2 wheels )
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2010
    axle
    Thanks but this is the second trailer of this design. I wouldn't swap the RR suspension for that of a horse cart.
    what is the difference between D2 and the current RR
