Results 1 to 10 of 11
Thread: 12V IGN and Dimmer wires? Puma.
    May 2014
    Tamworth NSW
    I'm installing an air compressor, and need to source a 12V ignition switched power and a dimmer wire for the fancy light up switchgear (compressor will be run directly off the battery).
    Are others getting the 12V IGN wire from the cigarette lighter, or is there a better place?
    Where is a good spot to get a the dimmer wire? Out of the back of the headlight switch?
    Any tips on getting this area of the dash apart would also be helpful.
    All from the Aux (lighter) socket..
    Assuming the lighter is illuminated and dims also.
    I would avoid cutting in elsewhere if possible.
    May 2014
    Tamworth NSW
    I need a min 8A fused circuit, so surely the cig lighter would be at least 15A? I never use it, so can't recall if it's got an illumination ring around it.
    Apr 2013
    NSW, Sydney
    Puma cigarette lighter circuit is fused at 20 amps and the illumination ring runs off that same circuit (I.e. only 2 wires run to the lighter socket).
    What are you planning to use the dimmer wire for?
    Opening the centre dash is easy, see my post in the defender section titled "easy diy relocation of the 12v outlet to somewhere more useful (puma 110)" - sorry on my phone and can't get the link working.
    May 2014
    Tamworth NSW
    Quote Originally Posted by FeatherWeightDriver View Post
    I'm installing an ARB air compressor, so the Carling switch needs a 12V ignition and a dash illumination (not dimmer, my mistake) input for the globes.
    I've looked up the Carling switch patent (Patent US5105059 - Environmentally sealed switch construction - Google Patents), but not much indication of what trickery happens inside. It looks just like you'd think- a simple switch that just supplies 12V to the relay in the compressor to activate the high current circuit. The dash illumination just serves for a pretty light when it's dark it seems. Since I'm not running air lockers, I'm only using the isolation switch to activate the compressor but have forward compatability if I ever decide I wish to go that way.
    n plus one Guest
    Quote Originally Posted by Toxic_Avenger View Post
    You can easily pick up accessory power and illumination from the back of the stereo. Why do you need an 8 amp supply? A compressor would be much higher and should likely be run through a relay.
    PS the amp rating of your accessory doesn't determine the size of the fuse - it determines the required cable size, which in turn determines the fuse size - it's not the same thing and fuses are there to protect wiring, not devices.
    May 2014
    Tamworth NSW
    Quote Originally Posted by n plus one View Post
    The compressor I'm using has an internal relay, and it's own power source wired directly to the battery (with twin 40A fuses). It's beefy wiring running to it too.
    Not sure why they recommend the 8A fused circuit for the switch, I believe its only function is to power the coil in the relay when activated so it can pull in the high current side of the circuit.
    As for the device, its rated to draw up to 50A under heavy load, so there is probably (I hope!) a bit of wiggle room in the combo of wiring and fuses that they've engineered into the package.
    Gold Coast Hinterland
    8a would be for remote control ( stop/start)
    n plus one Guest
    I run the same compressor using the stereo supply to run the relay - works perfectly.
    AndyG's Avatar
    AndyG is offline YarnMaster Silver Subscriber
    Jan 2014
    PNG
    Well you've almost answered my question before i get to ask it.
    I get my Defender in two weeks, so sight unseen:
    Best way to get access to the wires behind the stereo, or how do you pull the Stereo out?
    Colors for appropriate wires
    Ignition
    Illumination
    To feel a Carling switch for Driving lights as part of a Traxide loom
    thanks
    apologies to Socrates
    Clancy MY15 110 Defender
