Results 1 to 10 of 19
Thread: Vnt exhaust impeller q.
    May 2006
    Woolgoolga
    Took my rangie for a test run and this awful noise was coming from the turbo.
    So stripped it down (I had put a bearing kit in it ages ago and can't remember if I noticed the issue or not and was going to look into it) and noticed the steel disc that sits behind the exhaust impeller moves all over the place.
    So went through my box of stripped turbo's (2 more the same) and can't seem to find any extra parts that would retain this.
    Is it just sandwiched between the impeller and that cartridge? I wouldn't think so.
    Kiwiland
    Yep. They rattle around on my spare turbos too.
    May 2006
    Woolgoolga
    This is extremely noisy.
    Kiwiland
    The two VNT's which are garage ornaments rattle, but I've never heard anything from the GT1646V on the skoda.
    Sep 2013
    Darwin
    12.74 MB
    Small tack weld?
    Kiwiland
    Quote Originally Posted by workingonit View Post
    Small tack weld?
    Perhaps a small shim, spring or washer instead.
    May 2006
    Woolgoolga
    My other vehicles with vnt's don't make noises.
    With a shim, the steel disc would wear as it spins agains the cartridge. A little confusing
    Kiwiland
    Quote Originally Posted by Vern View Post
    The heat shield should be stationary.
    May 2006
    Woolgoolga
    Yeah thats what I thought.
    May 2006
    Woolgoolga
    But how is it held there??
