I think that the correct LT230 front output flange for your model is STC4370.
Regards,
Mike.
G'Day All,
The transfer case front output flange on my 2004 TD5 110 is a D2 flange.
I want to change it back to the original Defender flange.
Can anyone tell me what the part number is ?
Thanks.
Mellow Yellow
No matter what the problem - there's a solution. You've just got to find it.
2013 Discovery 4 TDV6 3.0
2015 Defender 90 - The TARDIS (Gone)
2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
2001 Discovery II TD5 (Gone)
1986 County V8 (Gone)
 Master
						Master
Regards,
Mike.
Have since found out that STC4370 is for Defenders 2007 on. STC4858 is the correct part for my 2004 Defender.
Thanks anyway.
Mellow Yellow
 Master
						Master
						The part number the I quoted is the part number for TD5s and TDCIs.
The part number fits the 43D transfer case box "as fitted standard to TD5 and 2007 onward model TDCI Defenders".
I believe that the part number that you have quoted is for a 4 bolt differential flange, used when changing to 4 bolt flange on the diff, from a 3 bolt "discovery" flange.
Regards,
Mike.
Thanks Mike.
You are absolutely spot on.
STC4858 is the flange for the diff.
Mellow Yellow
